Old 05-21-2016, 05:09 AM   #1
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
Originally Posted by Bluevitz-rs View Post
a 195 on a 5.5" rim is going to be pulling the sides of the tire up. You need to move up to a 7" wide rim to maximize the tire contact patch.
actually its doing fine without an issue..stock is 185..i just plus size to 195...they have tire chart, you can use the chart.......
Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Tire rotation question vasonline Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 02-15-2016 10:42 AM
Costco Tire Damage Issue nkaufman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-16-2015 06:48 PM
Tire Size and FE question GMKing Fuel Economy Forum 8 09-01-2009 09:20 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
