Old 05-22-2016, 10:09 AM   #19
mik23
Drives: yaris 2005
Update
you r right
there is a leak I tried to turn on AC today and no cold air. I dont know what happens but it seems the mechanic was lying that there is no leak.
Now, I am unsure how / where / to test the system / leaks
mik23 is offline   Reply With Quote
Old 05-22-2016, 12:21 PM   #20
bronsin
bronsin's Avatar
First get another mechanic and explain what the last one did!
Fro m what u learned here the new guy needs to put dye in the system to spot the leak right?
Old 05-22-2016, 12:30 PM   #21
mik23
Drives: yaris 2005
I am thinking to go and speak with him why he lied
Old 05-22-2016, 12:31 PM   #22
mik23
Drives: yaris 2005
I think he used a big machine with dye in it and looked with uv and confirmed no leaks
Old 05-22-2016, 12:59 PM   #23
Besides a leak, if the pressure sensor is bad, the system will also not run. If the mechanic has a Toyota specific electronic test tool he can read the codes and signal outputs from the AC ECU (this can not be done with a generic code reader)
Old 05-22-2016, 01:21 PM   #24
mik23
Drives: yaris 2005
I dont think he checked the pressure sensor is that something i can check got some tools and multimeter
Old 05-22-2016, 06:19 PM   #25
Update
Recharge the gas and its now ok.
Thanks All
According to that post, you were working after a recharge. If that was the case, then the pressure sensor is working.
Old 05-28-2016, 02:00 PM   #26
mik23
Drives: yaris 2005
Gents
Update I have got a minor leak in condenser.
Initally I was told its all ok when I went back they show me the leaks. I said why you regass when there was a leak just to take money. He said you sort out the condenser and I will regass free. I am really disappointed.
Asked him if this is a minor leak can he seal that he replied this will damge the compressor and more faults. he suggested replace the condenser.
moving forward I will not trust any mechanic.
Looking for a used condenser to replace thanks for all it is highly appreciated.
Thinking to replace the conderser by myself then go for free regas.
Any advise would be highly appreciated.
Old 05-28-2016, 05:43 PM   #27
bronsin
bronsin's Avatar
Can't help with the ac but there are good mechanics out there.
As well as a lot of shady ones.
Old 05-29-2016, 04:15 AM   #28
mik23
Drives: yaris 2005
Gents
I am thinking to try replacing o ring on this. Can any one help what where to change
Need help troubleshooting air conditioning davislau DIY / Maintenance / Service 7 07-15-2015 10:54 AM
air circulation fan problem tomdf DIY / Maintenance / Service 8 12-10-2012 06:53 AM
Air conditioning Blower satdan DIY / Maintenance / Service 1 09-13-2012 02:13 PM
max air conditioning button Idahotom General Yaris / Vitz Discussion 0 07-06-2011 09:41 PM
air conditioning markpeppie General Yaris / Vitz Discussion 34 06-20-2006 01:17 PM
