#19 |
![]() ![]() Drives: yaris 2005 Join Date: Mar 2016
Update
you r right there is a leak I tried to turn on AC today and no cold air. I dont know what happens but it seems the mechanic was lying that there is no leak. Now, I am unsure how / where / to test the system / leaks |
#20 |
First get another mechanic and explain what the last one did!
Fro m what u learned here the new guy needs to put dye in the system to spot the leak right?
#21 |
I am thinking to go and speak with him why he lied
#22 |
I think he used a big machine with dye in it and looked with uv and confirmed no leaks
#23 |
Besides a leak, if the pressure sensor is bad, the system will also not run. If the mechanic has a Toyota specific electronic test tool he can read the codes and signal outputs from the AC ECU (this can not be done with a generic code reader)
#24 |
I dont think he checked the pressure sensor is that something i can check got some tools and multimeter
#25 |
According to that post, you were working after a recharge. If that was the case, then the pressure sensor is working.
#26 |
Gents
Update I have got a minor leak in condenser. Initally I was told its all ok when I went back they show me the leaks. I said why you regass when there was a leak just to take money. He said you sort out the condenser and I will regass free. I am really disappointed. Asked him if this is a minor leak can he seal that he replied this will damge the compressor and more faults. he suggested replace the condenser. moving forward I will not trust any mechanic. Looking for a used condenser to replace thanks for all it is highly appreciated. Thinking to replace the conderser by myself then go for free regas. Any advise would be highly appreciated. |
#27 |
Can't help with the ac but there are good mechanics out there.
As well as a lot of shady ones.
#28 |
Gents
I am thinking to try replacing o ring on this. Can any one help what where to change |
| Need help troubleshooting air conditioning | davislau | DIY / Maintenance / Service | 7 | 07-15-2015 10:54 AM |
| air circulation fan problem | tomdf | DIY / Maintenance / Service | 8 | 12-10-2012 06:53 AM |
| Air conditioning Blower | satdan | DIY / Maintenance / Service | 1 | 09-13-2012 02:13 PM |
| max air conditioning button | Idahotom | General Yaris / Vitz Discussion | 0 | 07-06-2011 09:41 PM |
| air conditioning | markpeppie | General Yaris / Vitz Discussion | 34 | 06-20-2006 01:17 PM |
