Old 05-26-2016, 06:50 PM   #1
Mareo
Drives: Yaris M2 1.0
Instrument cluster 0D660D swap
Hi All, I think this post might be really helpful for me.
I need to convert my European Yaris MK2 to the UK specifications: this means (unfortunately ) that I need to replace my actual speedometer. Its number is 83800-0D660-D, for a 1.0l petrol 3dr 2007 Yaris with manual transmission.
I've checked for second hand UK speedometers and there are different types both digital (numbers 83800-0D650D or *0D650 or *0D490D or *0D680D) and analogic (mainly 83800-0DG60).
In any case I need to extend the cable to fit the new connections but I'm really afraid that the single pins will not correspond similarly between the European and the UK speedometers.
Then my main concerns/questions are:
- which is the best part number that matches with my 0D660-D, or do I need to match the same engine displacement, doors, gearbox?
- Is there any pin wiring conversion I need to consider when cabling the new speedometer?
- If I buy a new digital UK speedometer it will display the speed pointing toward the right seat, while my car is left-hand drive. Is it possible to use my LHD speedometer framework (I've already disassembled my actual one and there is a mirror inside)? If not, is it possible to buy an analogic speedometer without any problem in the wiring connection (i.e. different pin locations and cabling)?
Thanks in advance for your help,
Matteo
Mareo is offline   Reply With Quote
Old 05-26-2016, 07:41 PM   #2
Matteo
Definitely avoid the digital one, as it will point in the wrong direction and not be visible from the driver's seat.
For the Analog ones, the key is the match the year and features (traction control, ABS, etc.) of your car.
The UK and European ones have the connectors in the same place, so you will not have to extend the harness.
Old 05-27-2016, 01:33 PM   #3
Mareo
Thanks a lot CTScott.
Actually I can only find Analog speedometers of 2010 or 2011 for 1.3l petrol and 1.4l diesel, all 5 door cars (mine is a 1.0l 3doors). Do you think it may fit my specifications?
Unfortunately it's a shame that I cannot use an UK digital speedometer, it's plenty of it.
cluster, digital, gauges, intsrument
Custom Instrument Cluster LED Color Change Service CTScott Items for Sale by private party 74 06-10-2022 01:29 AM
Cruise Control - 07/08 Sedan - Instrument Cluster CB900F2 DIY / Maintenance / Service 4 02-23-2011 07:03 AM
DEAD INSTRUMENT CLUSTER! yaris2010RS General Yaris / Vitz Discussion 21 02-24-2010 12:06 PM
Sedan Instrument Cluster to LB Instrument Cluster Malaya1221 Cosmetic Modifications (Exterior/Interior) 2 12-02-2008 10:05 PM
instrument cluster swap S -> LB elo79 Performance Modifications 1 12-21-2006 10:22 AM
