Old 06-02-2016, 01:56 PM   #1
Mareo
Drives: Yaris M2 1.0
Thanks for your info, I've just bought and received an analog cluster (83800-0DG30). It works fine but the "High engine coolant temperature" light is always on. Do you know any reason for that?
Thanks
Mareo is offline   Reply With Quote
Old 06-07-2016, 07:14 PM   #2
Thanks
The instrument cluster gets the engine temperature from the ECM by CAN bus message, so it is very strange that the light is always on. Does the "cool" light come on when you turn the key on?
Old 06-08-2016, 02:51 PM   #3
Mareo
Hi CTScott, unfortunately not, the "cool" light was always off while the "hot" one on.
It's odd that when swapped to my original speedo and I turned the key on, the "hot" ligth appeared for 1sec and then was replaced by the (correct) "cool" ligth.
Do you think there was something wrong in the ECM? I don't think so because I suppose the speedometer is just receiving signals not sending to the ECM (am I right?).
Do you think the new speedometer is not calibrated properly and reads the same CAN signal as the original speedo but with a different range cool-hot?
Anyway, tomorrow I'm going to swap again to the new speedo and check if the light is still on. Do you have any alternative in case it's still there?
Thanks.
Old 06-08-2016, 07:55 PM   #4
Thanks.
Hopefully the issue is that your coolant temp sensor is actually bad. I have experimented with clusters from other regions and the temperature lights always worked correctly, as the cluster just receives a CAN bus signal from the ECM with the temperature. Definitely not an ECM issue.
Old 06-09-2016, 02:31 PM   #5
Mareo
Hi CTScott, I don't know the reason but now the light is off.
So it looks like everything is working fine.
Thanks again,
Matteo
Tags
cluster, digital, gauges, intsrument
Custom Instrument Cluster LED Color Change Service CTScott Items for Sale by private party 74 06-10-2022 01:29 AM
Cruise Control - 07/08 Sedan - Instrument Cluster CB900F2 DIY / Maintenance / Service 4 02-23-2011 07:03 AM
DEAD INSTRUMENT CLUSTER! yaris2010RS General Yaris / Vitz Discussion 21 02-24-2010 12:06 PM
Sedan Instrument Cluster to LB Instrument Cluster Malaya1221 Cosmetic Modifications (Exterior/Interior) 2 12-02-2008 10:05 PM
instrument cluster swap S -> LB elo79 Performance Modifications 1 12-21-2006 10:22 AM
