Old 06-13-2016, 01:46 AM   #1
CoryM
Drives: 2009 5-door, 5-speed
The rubber tube on the pins are just there to reduce the chances of having a rattle, or clunk. Without them, the calipers can audibly rattle on bumps, or when applying brakes. Pins that have the rubber tubes are more likely to seize up since the rubber is sticky. Make sure to lube them well.
It won't hurt anything for it to be missing. Chances are the Toyota clearances are tight enough to keep it from rattling. However, the rubber dust boot on the outside is definitely critical to keep the pins moving freely and not wearing the bores from dirt.
Cheers.
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
Help Needed - Brake Light Question *MAD DOG* Cosmetic Modifications (Exterior/Interior) 21 02-08-2009 05:32 AM
ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS kargoboy YarisUniverse 11 01-20-2009 04:43 PM
Front Bumper Question tca4 Cosmetic Modifications (Exterior/Interior) 8 01-30-2007 03:58 PM
Stupid Front bumper question (sedan) amishpriest General Yaris / Vitz Discussion 17 07-26-2006 03:10 AM
