Old 06-27-2016, 12:08 AM   #1
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
That doesn't reset the battery :-)
Sent from my LG-D801 using Tapatalk
tarkus is offline   Reply With Quote
Old 06-27-2016, 01:08 AM   #2
rabbito
rabbito's Avatar
you throw the battery on the floor and kick them couple times, thats how you reset them
Cosmetic: Toyota red emblem
TB Spacer + TB polishing rabbito Performance Modifications 6 06-25-2016 12:08 AM
Echo HatchBack 15X6.5" 42ET Nitto NeoGen 205/50R15 . Rear Spacer or not ! mpcv2000 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-10-2014 10:32 PM
Best Rear Spacer SeriousBlack Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 08-22-2011 02:44 AM
Wheel/hub spacer, PLS help evo165 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 08-18-2009 02:21 AM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
