Old 06-19-2016, 01:45 PM   #1
rabbito
rabbito's Avatar
TB Spacer + TB polishing
im going to hit up shop this weekend that provides TB spacer and TB polishing on 1NZ..i will update 😎
Sent from my SM-J700F using Tapatalk
Cosmetic: Toyota red emblem
Old 06-20-2016, 10:36 PM   #2
SirDigby
Drives: 2007 yaris 3 door
seems expensive considering you can get a 1zzfe throttle body for $30
Old 06-20-2016, 10:37 PM   #3
rabbito
rabbito's Avatar
its about $90..its not bad...😕
Old 06-21-2016, 09:36 PM   #4
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
I don't recall the last time i saw one for less than 90?
Old 06-21-2016, 10:08 PM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
You pick yard. $30 all day. =P
Old 06-24-2016, 10:10 PM   #6
SirDigby
i'll sell you 1000 of them at $60 then you can make $30,000
you can get them out of like 4 different cars that were built for like 6 years. they are in almost any modern pull&pay
Old 06-25-2016, 12:08 AM   #7
rabbito
rabbito's Avatar
we have a lot of fast and furious watchers imaging things..😂😂😂😂
Echo HatchBack 15X6.5" 42ET Nitto NeoGen 205/50R15 . Rear Spacer or not ! mpcv2000 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-10-2014 10:32 PM
Spacer 1NZ-FE to 1ZZ-FE EdgarTRD1.8 Caribbean 2 03-24-2012 10:37 AM
Best Rear Spacer SeriousBlack Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 08-22-2011 02:44 AM
Wheel/hub spacer, PLS help evo165 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 08-18-2009 02:21 AM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
