#1 | |
#2 | |
![]() Drives: 2010 Yaris Join Date: Mar 2016
Just the absurd small ones or the 'normal' pins as well. i might as well do some proper wiring vs my inserts. I'll send you a PM invader166 would you mind posting how you wired this ? Was my description correct?
2010 hatchback Fog lights, Kenwood touchscreen, backup camera |
#3 | |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
Generally speaking, the relay only comes on for 1/2 a second or so, to get the wiper moving. It will return to it's original position as a result of the eccentric cam profile of the motor. You do hear it click on and off when it operates. I guess you can also make/buy an enclosure for it, to not have all the circuitry exposed, but it's completely up to you. I never really bothered with that, and ended up mounting underneath the steering column, hidden from view, but still able to access it to adjust the timing with relative ease.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
Pumpman
Alright! Finally had a chance to refresh my memory.
I only used 4 connections to wire up the delay unit: 12V+ ---> Black wire from front wipers connector. 12V- ---> Missing wire from rear wiper connector. (pin 6) NO ---> White wire with black stripe on rear wiper connector. (or any other ground wire) COM ---> Blue wire from rear wiper connector. Should work as if it were originally fitted from the factory.
#5 | |
| Removing rear wiper | fred812 | Cosmetic Modifications (Exterior/Interior) | 34 | 01-27-2013 12:22 AM |
| Slight mod to rear | NickNickNick | Cosmetic Modifications (Exterior/Interior) | 4 | 05-11-2006 01:03 AM |
