Old 06-27-2016, 08:47 PM   #1
ercdvs
Drives: 2010 Yaris
I have the pins on hand if anyone needs them and I only charge $3 each for them.
Just the absurd small ones or the 'normal' pins as well. i might as well do some proper wiring vs my inserts.
I'll send you a PM
invader166 would you mind posting how you wired this ? Was my description correct?
2010 hatchback
Fog lights, Kenwood touchscreen, backup camera
ercdvs is offline   Reply With Quote
Old 06-30-2016, 12:12 PM   #2
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
I'll send you a PM
You bet! I'll post how I did the wiring in the next few days or so. I'm currently away since I do travel a lot because of my job.
Generally speaking, the relay only comes on for 1/2 a second or so, to get the wiper moving. It will return to it's original position as a result of the eccentric cam profile of the motor. You do hear it click on and off when it operates.
I guess you can also make/buy an enclosure for it, to not have all the circuitry exposed, but it's completely up to you. I never really bothered with that, and ended up mounting underneath the steering column, hidden from view, but still able to access it to adjust the timing with relative ease.
Old 07-07-2016, 07:15 PM   #3
invader166
Pumpman
Alright! Finally had a chance to refresh my memory.
I only used 4 connections to wire up the delay unit:
12V+ ---> Black wire from front wipers connector.
12V- ---> Missing wire from rear wiper connector. (pin 6)
NO ---> White wire with black stripe on rear wiper connector. (or any other ground wire)
COM ---> Blue wire from rear wiper connector.
Should work as if it were originally fitted from the factory.
Old 07-08-2016, 08:04 AM   #4
ercdvs
Drives: 2010 Yaris
Thank you sir, I'll give it a go later this weekend
2010 hatchback
Removing rear wiper fred812 Cosmetic Modifications (Exterior/Interior) 34 01-27-2013 12:22 AM
Slight mod to rear NickNickNick Cosmetic Modifications (Exterior/Interior) 4 05-11-2006 01:03 AM
