![]() Drives: lowered/ exhaust Join Date: Apr 2016
BRAKE INSPECTION HELP
Rear shoes don't wear out as fast as fronts because of the breaking ratio (80% front brakes and 20% rear brakes ) furthermore a Yaris is such a light vehicle that it doesn't require much brake force to stop the vehicle and thus your brakes will last longer then most other cars. I currently have a 15 Yaris and previously a 10 sedan. My sedan had 67k miles before I sold it and the front brakes were still at 9mm (this vehicle was an automatic)
#2 | |
![]() Drives: Yaris 2008 Join Date: Apr 2013
also - is there really a small inspection hole behind each wheel to inspect the brake wear...
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
The official numbers from Toyota are 12mm standard thickness and 1mm minimum thickness for the front disc pads with the rear shoes being 4mm standard thickness and 1mm minimum thickness. So if you're at 8mm front and 3mm back than you have plenty of brake life remaining.
The front discs can be inspected just by taking the wheel off but for the rear drums you need to take the brake drum off the hub to inspect the shoe thickness. |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| BRAKE INSPECTION HELP | Abk911 | DIY / Maintenance / Service | 0 | 06-27-2016 06:13 PM |
| Front brake caliper pins | DarkSkyGhost | DIY / Maintenance / Service | 7 | 06-10-2014 08:05 AM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 07:34 PM |
| Brake inspection at 92,000 miles (original brakes)... | Kal-El | General Yaris / Vitz Discussion | 3 | 10-03-2010 01:00 PM |
