Old 09-16-2010, 11:27 AM   #1
Kal-El
Kal-El's Avatar
Brake inspection at 92,000 miles (original brakes)...
Had a coupon for a free inspection at my Toyota dealer and received great news. The front pads still have 45% left! Sweet! I thought sure I'd be closer to the need for replacement at 92,000 miles. Gotta love the Yaris. Many vehicles need replacement by 50,000 miles, particularly heavier vehicles.
Old 10-03-2010, 12:50 AM   #2
vwtech
Drives: 09 jetta tdi dsg
did they check the rear shoes? I've been meaning to pull mine off to check them out I assume they have plenty left.
vwtech is offline   Reply With Quote
Old 10-03-2010, 10:12 AM   #3
Kal-El
Kal-El's Avatar
The rear drums generally last a lot longer than front pads (which of course you know). The service was for a brake inspection which I assume they would at least take a quick look at the rears. I was mostly concerned with knowing the life of the fronts which are, as mentioned, 45%. The rears are probably barely used.
Old 10-03-2010, 01:00 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
This is good news. I've got about 46K on the clock and was thinking the brakes would have to be done soon.
yeah mine too, i have an appointment tomorrow for a 96k check up , last time i went i was at 60% so now I'll probably be at 55%. I barely use my brakes only to come to a full stop otherwise its all downshifting but yes the weight of the Yaris helps a lot
Nobody makes a full stop in Montreal! LOL
2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. trini_per4mance General Yaris / Vitz Discussion 100 06-08-2022 09:54 PM
How many miles before you had to replace brakes, tires, battery, etc ... Yaris_Fan DIY / Maintenance / Service 53 01-15-2013 11:52 AM
Brake Light without Brakes? slothman86 General Yaris / Vitz Discussion 8 10-01-2009 08:26 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
