Old 06-27-2016, 09:14 PM   #1
B.B._07
Drives: 07 5dr
The official numbers from Toyota are 12mm standard thickness and 1mm minimum thickness for the front disc pads with the rear shoes being 4mm standard thickness and 1mm minimum thickness. So if you're at 8mm front and 3mm back than you have plenty of brake life remaining.
The front discs can be inspected just by taking the wheel off but for the rear drums you need to take the brake drum off the hub to inspect the shoe thickness.
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
BRAKE INSPECTION HELP Abk911 DIY / Maintenance / Service 0 06-27-2016 06:13 PM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
Brake inspection at 92,000 miles (original brakes)... Kal-El General Yaris / Vitz Discussion 3 10-03-2010 01:00 PM
