Old 07-10-2016, 11:04 PM   #2
alanwagen
maybe clogged
Originally Posted by laurenth View Post
Hi,
I have an 04 1.0 and the front windshield washer pump was getting weaker and weaker on me then totally quit so I decided to replace it.
So I plug the new one and it doesn't work... after switching the wiring with the rear one it runs fine: it's apparent that it isn't getting any juice.
The fuses under the hood are all ok, where should I look? do switches at the steering go bad?
If at anytime you ran just water, you could have algae or some other junk. Check to be sure the tank is clean and nothing in clogging the intake and then go from there.
Removing Windshield Washer AGlobalThreat Fuel Economy Forum 14 05-02-2011 07:27 PM
Windshield washer fluid Twistoffate0817 General Yaris / Vitz Discussion 5 05-12-2010 12:47 PM
Windshield Washer indicater always on mlaverdiere General Yaris / Vitz Discussion 3 01-17-2010 02:43 PM
Windshield Washer Indicator captainm27 General Yaris / Vitz Discussion 25 01-21-2009 07:26 PM
New TSB Bulletin For Windshield Washer Sprayer Yaris General Yaris / Vitz Discussion 14 06-01-2007 01:47 PM
