![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
Bleeding ABS modules and the entire system can be a pain. As can dealing with all the brake lines. I'm not sure the average backyarder would enjoy doing that job. I am not certain, but I think the module can be replaced without needing re-programming on the Yaris.
I'd guess a professional would be a good idea. Keep in mind that an independent shop can probably do the job for less, especially if you are OK with a used ABS module. |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| abs rear hub assy and sensor change + new harness install. | limochong | DIY / Maintenance / Service | 2 | 11-13-2014 04:58 AM |
| Rear Speed Sensor Install Help? (ABS Sensor) | towerofpower | DIY / Maintenance / Service | 2 | 04-07-2014 06:32 PM |
| What's with ABS? | jgag123 | Canada | 9 | 01-01-2009 06:04 PM |
