Old 07-20-2016, 11:48 AM   #1
Ramon1691
Ramon1691's Avatar
Drives: 2007 Yaris hatchback
Hi thanks for your replies i don't have to add oil between oil changes and it doesn't drop while is running also is not the filter either I was going to replace the valve cover next week I saw a post about a guy Hershey saying it was the head gasket on his but how can that be if it's on top of the engine the leak is like right next to the timing cover its a little piece of that block that's a little deep and the oil collects in there my oil cap is not milky or anything like that and there is no oil on my spark plugs or my coolant so I'm puzzled will change the valve cover gasket as you suggested and go from there
Ramon1691 is offline   Reply With Quote
Old 07-20-2016, 01:38 PM   #2
bronsin
bronsin's Avatar
Originally Posted by Ramon1691 View Post
Hi thanks for your replies i don't have to add oil between oil changes and it doesn't drop while is running also is not the filter either I was going to replace the valve cover there
If there's no drop in oil level on the dipstick and no oil dripping from the engine While running you don't have a problem.
If you want to play around and change gaskets for grins and giggles that's OK but probably not necessary.
Good luck!
Old 07-20-2016, 02:02 PM   #3
Ramon1691
Ramon1691's Avatar
Thank you all for you explanations I really appreciate it I'm glad I came across This forum is very helpful :)
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
