Old 07-26-2016, 09:45 PM   #1
Rylinkus
Drives: 2012 Mitsu Ralliart Sportback
Correct. The next stop for that wire is CA1 - Pin 1, which is the front right wire on the connector on the top right in this picture:
CA1 color? Or diagram?
And honestly, thanks. I very much appreciate your input
Rylinkus is offline   Reply With Quote
Old 07-26-2016, 10:03 PM   #2
Green, as in the front row, top right connector pictured above.
Old 07-27-2016, 05:24 PM   #3
Rylinkus
.14 volts on the back of the connector, green wire. Not sure how that connector pops out so I have not measured the pin...
Old 07-27-2016, 07:58 PM   #4
OK. The next stop is the under dash fuse panel. Did you already check the 10A Gauge fuse under the bottom of that area?
Old 07-27-2016, 09:02 PM   #5
Rylinkus
Fuse is intact. And I replaced it to be sure. Did not measure voltage under there. Too dark to do at this point.
Sway Bar End Link tip tmontague DIY / Maintenance / Service 0 03-31-2015 11:34 AM
Sway bar link replacement salmonz DIY / Maintenance / Service 8 12-09-2010 09:30 AM
