Old 07-27-2016, 07:58 PM   #16
Originally Posted by Rylinkus View Post
.14 volts on the back of the connector, green wire. Not sure how that connector pops out so I have not measured the pin...
OK. The next stop is the under dash fuse panel. Did you already check the 10A Gauge fuse under the bottom of that area?
Sway Bar End Link tip tmontague DIY / Maintenance / Service 0 03-31-2015 11:34 AM
Sway bar link replacement salmonz DIY / Maintenance / Service 8 12-09-2010 09:30 AM
