Old 07-26-2016, 11:52 PM   #1
alias06
Drives: 2008 Red Toyota Yaris
Originally Posted by rabbito View Post
converting to E85 on stock piston with my current mods won't gain anything? ..LOL 😂😂😂😂😂 you joking right..?
only converting to E85 doesnt do anything..they actually have E85 conversion just to change the fuel module with E85 plugs for stock injectors but changing to larger injector and slight timing advance on ecu do gain hp..
E85 tuning isnt same mod as putting on cold air intake and gaining 5hp with sound effects..lol 😂😂😂
I don't think you understand the concept behind E85. E85 produces less heat when burned, so therefore you need more fuel to make up for the loss of power, that is why you need injectors. With more fuel you need more air flow, which you don't have, a TB spacer and polished TB isn't increasing air flow, its reducing friction losses. Advancing timing to compensate for the power that was lost due to the switch of fueling doesn't necessarily mean that you are making more power. Unless you have dyno results to prove otherwise? An overlay of the stock setup and the current setup that you have. If you are producing more than 15WHP I'd be greatly surprised.
alias06 is offline   Reply With Quote
Old 07-27-2016, 03:33 AM   #2
rabbito
rabbito's Avatar
https://youtu.be/eiSbVvi0pDg
here is video of only E85 + timing advance only with dyno...lol...15hp? rofl..
keyboard racer these days, write like they actually have the mods in their yarus..😂😂😂😂😂
goto youtube and search "vios e85" or "yaris e85"..most of the videos will have standard e85 + timing advance tuning(basic)..
Cosmetic: Toyota red emblem
Old 07-28-2016, 12:38 AM   #3
alias06
Is that a video of your car being tested? It's in Thai and I don't understand what they are saying, I guess I'd have to take your word for it saying that it is stock. Still 23hp measured at the hubs isn't power measured to the ground so you'll still have a higher reading, I wasn't far off from my 15hp guess. If you are looking for a fast car, the Yaris isn't it end of story.
Old 07-28-2016, 02:52 AM   #4
rabbito
rabbito's Avatar
its called fast forward through the video and look at the dyno charts...yeah 23hp from stock...rofl
put some photos of your car..bet you got some turbo whistler on your exhaust 😂😂😂😂
Old 07-28-2016, 07:02 AM   #5
alias06
I saw the dyno charts that is why I said 23hp measured at the hubs. Stock didn't come with a turbo, but that car appears to have a boost gauge??? Lol
Old 07-28-2016, 07:20 AM   #6
rabbito
rabbito's Avatar
sigh.....put some photos of your car man, stop being a keyboard racer..😂😂😂😂
Old 07-28-2016, 11:41 AM   #7
alias06
I'm not sure what photos of my car would prove? You want to see if I've modded my Yaris like yours? The answer is no, does that necessarily mean that I am ignorant and what I've said is false? No.
ImportRacer88's Photo Scavenger Hunt ImportRacer88 General Yaris / Vitz Discussion 8 02-28-2012 04:19 AM
Car Buying Scams nemelek Off-topic / Other Cars / Everything else Discussions 1 09-29-2011 08:01 PM
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 09:03 AM
