Old 07-26-2016, 04:01 AM   #11
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
Originally Posted by alias06 View Post
Converting to E85 on stock pistons, with your current mods, regardless of how much tuning you've done will yield no significant gains in power. You might have even lost power, just my $0.02 from a keyboard warrior, what do I know...
converting to E85 on stock piston with my current mods won't gain anything? ..LOL 😂😂😂😂😂 you joking right..?
only converting to E85 doesnt do anything..they actually have E85 conversion just to change the fuel module with E85 plugs for stock injectors but changing to larger injector and slight timing advance on ecu do gain hp..
E85 tuning isnt same mod as putting on cold air intake and gaining 5hp with sound effects..lol 😂😂😂
Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
ImportRacer88's Photo Scavenger Hunt ImportRacer88 General Yaris / Vitz Discussion 8 02-28-2012 04:19 AM
Car Buying Scams nemelek Off-topic / Other Cars / Everything else Discussions 1 09-29-2011 08:01 PM
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 09:03 AM
