![]() Drives: 2016 Yaris 5 Door LB Join Date: Jul 2016
Hub spacers and wheel spacers are one and the same AFAIK. Disc brakes or drums will not affect your use of wheel or hub spacers as long as the spacer clears the hub (hub spacer bore not smaller than factory hub bore).
No they are not. Hub spacers are bolted in place between the axle and the hub. Wheel spacers sit on either the disc or drum and are held in place by the wheel when it is bolted onto its studs.
| For Sale: Project KICS 15mm spacer w/ hub center | enviri | Items for Sale by private party | 1 | 04-14-2014 07:42 AM |
| WTT: 13mm hub spacer for a 10mm hub spacer. | marlondog | Items for Sale by private party | 0 | 11-18-2010 04:42 PM |
| anyone knows if wheel spacer can be placed behind the hub??? | jackrabbit | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 07-02-2010 06:41 PM |
| Penguin Garage Rear Hub Spacer Raffle!! | Penguin Garage | General Yaris / Vitz Discussion | 27 | 06-30-2009 01:05 AM |
