#1 | |
Here's an ebay listing for them for $8 each with free shipping: http://www.ebay.com/itm/Genuine-2016...35.m2548.l4275
#2 | |
![]() ![]() Drives: 2008 Yaris 5dr LB Join Date: Aug 2016
I know they always do, making a killing! I found some US OEM parts sellers online for around US$4 ea, but need to pay for shipping. I was asking MUSKOKA800 since he is from around here in Ontario, may be his dealership is more reasonable. Cheers. |
#3 | |
Cheers |
![]() Drives: Yaris 09 Join Date: Oct 2014
I just paid $23.23 CAD taxes included at an Ontario Toyota dealership a month or two ago.
Took it to Meineke for an oil change, asked them. To swap the bolts. They had no issue taking them out, and the old bolts sill looked alright, believe it or not. I'll post a pic of them later. I drive a 2009 hatchback btw. Having the new bolts gives me incredible peace of mind. |
#5 | |
#6 | |
The bolts are not the root cause and the new ones do not appear any different than the original ones. The root cause is two unsealed seams on the frame box above the lower subframe, which allow water splashed onto the bottom of the chassis to funnel into the metal sleeve where the bolt sits. Separately there is a TSB (T-SB-0078-12) with actual new bolts for 2007-2012 Yaris for a clunking noise from the front suspension, which occurs due to the bolts. This second TSB appears to be due to the original bolts either being a tad too long, or them stretching over time. This problem though is completely separate from the TSB above where the bolts corrode to the point of failure.
| Tags |
| control arm bolt, front suspension |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Warning - Broken control arm bolt! | CB900F2 | DIY / Maintenance / Service | 460 | 08-23-2020 05:54 PM |
| Front Lower Ball Joint Cotter Pin Replacment | GrayYaris | DIY / Maintenance / Service | 5 | 04-25-2014 04:30 PM |
| HELP PLEASE (lower trans bolts) | Iamdagerman | General Yaris / Vitz Discussion | 2 | 01-05-2014 10:16 PM |
