Old 09-08-2016, 01:02 PM   #1
dude, we all breathe the air. put the catalytic converter back on.
lightweight or underdrive crank pulley next
Old 09-09-2016, 01:06 AM   #2
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
I'm with thebarber on both points.
Get yourself a lightweight pulley next. (Or an entire set if you wanna go all out) It will really frees up some torque, but will make the car a bit jerky, as the engine will be more responsive.
And yes, definitly put a high-performance catalytic converter on, so it doesn't reduce performance, but still conforms to regulations.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog
invader166 is offline   Reply With Quote
Old 09-09-2016, 05:04 AM   #3
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
just like invader166 stated...i went with lightweight pulley right after all your mods....you will gain slight tq and faster rpm reach 😎
Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 01-17-2017, 12:16 PM   #4
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
Keep in mind that you can lose some low-end torque if you go too wide with the exhaust diameter.
…lightweight or underdrive crank pulley next
I vote for the underdrive pulley. It will also be lighter weight :-)
Sent from my LG-D801 using Tapatalk
tarkus is offline   Reply With Quote
Axelback or catback ?! TrYaris Performance Modifications 49 11-16-2012 03:05 PM
2" hitch ? would any one be interested in a 2" hitch reciver? Firefly General Yaris / Vitz Discussion 4 05-14-2012 10:30 AM
Custom Catback System Sabretooth Performance Modifications 48 07-10-2007 09:59 AM
Catback Exhaust by Greddy! elsteverino889 Performance Modifications 8 03-10-2007 11:05 PM
Catback exhaust? elsteverino889 Performance Modifications 5 03-09-2007 10:55 AM
