Old 09-09-2016, 01:06 AM   #1
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
I'm with thebarber on both points.
Get yourself a lightweight pulley next. (Or an entire set if you wanna go all out) It will really frees up some torque, but will make the car a bit jerky, as the engine will be more responsive.
And yes, definitly put a high-performance catalytic converter on, so it doesn't reduce performance, but still conforms to regulations.
Old 09-09-2016, 05:04 AM   #2
rabbito
rabbito's Avatar
just like invader166 stated...i went with lightweight pulley right after all your mods....you will gain slight tq and faster rpm reach 😎
Cosmetic: Toyota red emblem
Axelback or catback ?! TrYaris Performance Modifications 49 11-16-2012 03:05 PM
2" hitch ? would any one be interested in a 2" hitch reciver? Firefly General Yaris / Vitz Discussion 4 05-14-2012 10:30 AM
Custom Catback System Sabretooth Performance Modifications 48 07-10-2007 09:59 AM
Catback Exhaust by Greddy! elsteverino889 Performance Modifications 8 03-10-2007 11:05 PM
Catback exhaust? elsteverino889 Performance Modifications 5 03-09-2007 10:55 AM
