Old 09-19-2016, 09:38 AM   #14
tmontague
tmontague's Avatar
NO idea if the new bolts are any better but I installed 2 new bolts 2 years ago (purchased form the dealer). I covered them in marine grease before installation and when I removed the last year to check them out they were still covered in grease and in great shape.
Due to this I will not be taking them out to inspect until every 2 years. I do oil spray my car every spring but that likely does not get to the area where the bolt threads into
Tags
control arm bolt, front suspension
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Warning - Broken control arm bolt! CB900F2 DIY / Maintenance / Service 460 08-23-2020 05:54 PM
Front Lower Ball Joint Cotter Pin Replacment GrayYaris DIY / Maintenance / Service 5 04-25-2014 04:30 PM
HELP PLEASE (lower trans bolts) Iamdagerman General Yaris / Vitz Discussion 2 01-05-2014 10:16 PM
