Old 10-10-2016, 01:32 AM   #1
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
I fixed it that same night. Crazy idea that actually worked....
Drilled the hatch side where the mount goes big enough to put a toggler snap toggle in, and also drilled the mount itself. So now the mount is anchored to the hatch as if it were a TV or wall fixture. Cost me just the togglers I had on hand or about 4 bucks.
I think the mount has the most pressure on it while closing the hatch as the strut is pushing against the weld. Its the same length strut so I don't think its over extending.... That's more of the hatch mount to the car frame issue. If theframe cracks where the bolts are that would suck.
Check out my Build thread:
DIY: Rear shock, sway bar, and strut brace refit Tapokata DIY / Maintenance / Service 19 05-31-2016 01:05 AM
gap at upper strut mount? 428CobraJet Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 09-23-2015 06:53 AM
Rear hatch strut problem MiSFiTx87 DIY / Maintenance / Service 10 08-29-2014 11:15 AM
Strut mount (bearing) cause camber to be off? chaditotx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 07-02-2013 02:19 AM
DIY Camera Mount -- No Cost Version KCALB SIRAY DIY / Maintenance / Service 20 06-08-2009 03:12 PM
