Old 10-27-2016, 01:07 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
All this is provided the bleeders will open without snapping off first...
Old 10-27-2016, 01:13 AM   #2
CoryM
Drives: 2009 5-door, 5-speed
Yeah. It's a good idea to crack the bleeders loose by tightening them further. Then as soon as they move, stop and then loosen them. They are far less likely to break this way (as are all bolts. Especially small ones). Even if they do break, you know they are still sealed and will not leak.
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
Brake Fluid reservoir hose, is it suppose to be like this ? Goldenyaris DIY / Maintenance / Service 0 12-15-2014 07:31 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
Will this hold? Plastic bag vs brake fluid lamadoo DIY / Maintenance / Service 7 04-25-2013 03:35 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
