Old 12-15-2014, 07:31 AM   #1
Goldenyaris
Goldenyaris's Avatar
Drives: Yaris Sedan 2009
Exclamation Brake Fluid reservoir hose, is it suppose to be like this ?
Hi everyone
I have got 08 yaris sedan, with 2nz-fe. It got 40k miles on it.
I recently started to notice the sinking brake pedal. I quickly turned towards the brake master cylinder and noticed something like this, (attached file)
Is it normal ??? i can actually squeeze the pipe and the fluid struck between pipe and outer transparent shield will move.
Is this the major problem ? or my master cylinder is giving up ?
Here are the list of possibilities:
Leaking master cylinder.
Brake fluid is too old(about 6 years).
The hose has gone bad.
In the mean time the clutch pedal has also gone stiffer and if i am not wrong then in yaris the brake fluid is shared by the clutch fluid.
Thanks in Advance.
Don't drive faster than your guardian angel can fly.
Goldenyaris is offline   Reply With Quote
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Will this hold? Plastic bag vs brake fluid lamadoo DIY / Maintenance / Service 7 04-25-2013 03:35 AM
Anyone care to make a DIY on break flushing and bleeding? Hard_Yaris DIY / Maintenance / Service 19 05-04-2011 03:49 PM
