Old 11-02-2016, 08:48 AM   #1
bronsin
bronsin's Avatar
Originally Posted by bluethree View Post
i recently bought a brake fluid tester to test if the fluid is water-contained As the standard if the brake fluid should be changed
OOO tell me what you find out! Im invoved in a bake fluid controversy on another forum and am considering buying one to settle an argument.
I say an opened but resealed container of brake fluid will NOT absorb moisture even after three years!
In a car brake fluid is NOT sealed but its debateable how much water it will absorb. A FoMoCo study found less than 1% water after seven years in its cars.
Old 11-02-2016, 11:36 PM   #2
bluethree
Drives: e61
All right,i bought the brake fluid tester on uobdii, it is so cheap only cost ten dollars, it is chinese clone so i thought if it will cause any damage? But the measurement did not contact directly with the my car, So I'm not worried about that. but anyway, you should be careful using it if you really want to
bluethree is offline   Reply With Quote
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
Brake Fluid reservoir hose, is it suppose to be like this ? Goldenyaris DIY / Maintenance / Service 0 12-15-2014 07:31 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
Will this hold? Plastic bag vs brake fluid lamadoo DIY / Maintenance / Service 7 04-25-2013 03:35 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
