Old 11-03-2016, 12:00 AM   #1
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
Originally Posted by jefferelli View Post
I think your automatic transmission should already have a stock cooler by the radiator. (at least I assume the AT Yaris has one). I never really looked at the yaris for a cooler. On my AT 4runner it is built into the radiator ( I had to swap it out a couple months ago). But this was a good reminder that I should probably go ahead and swap my fluid in the Yaris. I am a little over 100,000 so def due. But now I will look for the cooler while I am under it out of curiosity.
What kind of transmission fluid did you use? I was just going to go with Toyota atf ws but looks like you used something different in the pic?
its also toyota ws fluid..only the packaging looks different...
i mean its only $50 here with the labor...not even a labor, machine with a sucker that just sticks in..i will just change mine every 40k...😅
Sent from my SM-J710F using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Complete flush for ATF change? Lance16 DIY / Maintenance / Service 29 07-05-2017 09:26 PM
Transmission Flush / Coolant Flush at 60k? ttpmurphy DIY / Maintenance / Service 7 08-29-2015 09:39 PM
Replaced my ATF markitect DIY / Maintenance / Service 6 01-02-2014 10:10 PM
ATF Drain and Fill DMZ DIY / Maintenance / Service 7 05-30-2013 11:01 PM
Do I need a transmission flush at 57K miles if 07 Yaris should last until 100k? lejulie DIY / Maintenance / Service 14 10-23-2011 07:43 PM
