Old 11-02-2016, 11:54 PM   #4
jefferelli
Drives: 08 Yaris HB
I think your automatic transmission should already have a stock cooler by the radiator. (at least I assume the AT Yaris has one). I never really looked at the yaris for a cooler. On my AT 4runner it is built into the radiator ( I had to swap it out a couple months ago). But this was a good reminder that I should probably go ahead and swap my fluid in the Yaris. I am a little over 100,000 so def due. But now I will look for the cooler while I am under it out of curiosity.
What kind of transmission fluid did you use? I was just going to go with Toyota atf ws but looks like you used something different in the pic?
jefferelli is offline   Reply With Quote
Complete flush for ATF change? Lance16 DIY / Maintenance / Service 29 07-05-2017 09:26 PM
Transmission Flush / Coolant Flush at 60k? ttpmurphy DIY / Maintenance / Service 7 08-29-2015 09:39 PM
Replaced my ATF markitect DIY / Maintenance / Service 6 01-02-2014 10:10 PM
ATF Drain and Fill DMZ DIY / Maintenance / Service 7 05-30-2013 11:01 PM
Do I need a transmission flush at 57K miles if 07 Yaris should last until 100k? lejulie DIY / Maintenance / Service 14 10-23-2011 07:43 PM
