Old 11-04-2016, 08:48 AM   #1
dogsridewith
Drives: 2007 2-door hatchback
What is your "regular" manual transmission oil?
Old 11-04-2016, 10:33 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
Non-synthetic 75w90. Toyota says GL5 or GL4 is fine, but GL4 is probably the better bet (less slippery). I don't remember what brand I used but likely Quaker State. Interestingly I called a Toyota dealer to buy some OE fluid and they said they just use bulk 80w90...... .
Let's be very clear: The Yaris gearbox is always going to be a little clunky/noisy. It's just not a very smooth box. It is, however, a very durable unit and works fine for the application with the correct oil. This is one of those cases where you should listen to the engineers. The only reason to consider different M/T oil is really if you are regularly operating outside of the temperature range they designed the car for. And yes, some of you are probably at the far end of that range in Winter. Yuck.
Cheers.
3rd Gear problems fbq262ken DIY / Maintenance / Service 16 02-26-2015 09:18 AM
2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) nookandcrannycar General Yaris / Vitz Discussion 7 02-22-2014 08:16 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
2nd to 3rd gear shift (manual tranny) tekmoe General Yaris / Vitz Discussion 13 12-11-2006 06:27 PM
