#1 |
![]() Drives: Toyota Yaris (2004) Join Date: Feb 2015
3rd Gear problems
I apologize if this topic or something similar is already posted.
I would like to ask if anybody else experienced this sensation: whenever I put the car on the 3rd gear, it is really a rough transmission. Often, in fact, I have to do it ultra slowly and with great care, or else it will stay neutral and do an awful noise (kind of like something stuck in your throat (the closest thing I can compare with)). Important to note that this only happens on the 3rd gear, all the other gear seem unaffected by this problem. My toyota yaris is the first edition, bought new in 2004. |
Mr. 155 and climbing
Drives: Seriously Modded 07 Sedan Join Date: Jun 2006
That would sound to me like either worn out syncros or most likely your 3rd gear itself has become very worn. When was the last time the transmission fluid was flushed and replaced? If this is the c50 transmission which I believe that it is then it is a somewhat of a known issue for the third gear wearing since it is your one to one ratio gear. Many times this will happen with people for 2nd gear as well however it all just depends on how hard the car is driven.
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. |
#3 | |
I believe the oil was never changed. It has 130,000km on the clock. |
#4 |
first thing you will want to do then anyway especially with the years of use and mileage is a flush and then moving to a synthetic trans fluid like AMSOIL, Redline, etc. You shoupd notice better shifting throughout.
#5 |
#6 |
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
I've got the same issue in mine, but I just wrote it off as a side effect of having a short-throw shifter and an engine-bay short throw bracket. It feels like it's actually trying to go into third before second has correctly disengaged, but the shift pattern blocker on the gear select rod should prevent that...
#7 | |
Was in an accident due to this in fact as I lost a bit of concentration in engaging the gear, luckily there was absolutely no damage between the two cars. |
#8 |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
it is most likely a transmission part (collar/synchro, not to go into detail as im no expert).
but i echo the post above, it is best to start with the cheapest for now by changing gear oil and see if the problem goes away. (or probably check your shifter bushings or shift cable functionality, as i think the only other option left is rebuild transmission). good luck! |
#9 |
What costs do you envisage I would incur to fix the problem?
#10 |
#11 |
where do you live? can you do any of it yourself?
#12 |
#13 |
The synchro is the least expensive part of the repair--you have to drop the gearbox, open it, remove the 4th and 5th gears from the shaft, and then reassemble it. I would expect it to be no less than 8 hours labor to do that, assuming there are no other problems. It may be cheaper to just get a used gearbox and have the shop do a remove & replace instead.
#14 | |
#15 |
Logan
Drives: 2009 Yaris Liftback Base MT Join Date: Jan 2015
Mine does this exact same thing in second. Im about to flush the transmission fluid and us redline. Ill post results
#16 |
#17 |
| 3rd Gear grind | hatchbackkid82 | General Yaris / Vitz Discussion | 92 | 02-15-2019 05:07 PM |
| 2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) | nookandcrannycar | General Yaris / Vitz Discussion | 7 | 02-22-2014 08:16 PM |
| yaris jerks a bit when shifting to 3rd gear. | abdallah380 | DIY / Maintenance / Service | 3 | 09-19-2009 03:45 PM |
| Yaris seems to get stuck in 3rd gear when going uphill | 47_MasoN_47 | General Yaris / Vitz Discussion | 16 | 08-24-2009 12:22 PM |
| 2nd to 3rd gear shift (manual tranny) | tekmoe | General Yaris / Vitz Discussion | 13 | 12-11-2006 06:27 PM |
