#19 |
![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
fack, lol i read that thread but somehow i stopped reading after #5!!
thanks! EDIT: Will the high beam indicator still work if i decide to get rid of HID and put back the stock halogens bulb later? Last edited by caineroad; 06-30-2012 at 05:28 PM. |
#20 | |
![]() Drives: VIOS (FL, 06 model) Join Date: May 2012
1. Green is to connect to left and right headlights (never mention whether is low or high beam) 2. Blue is to connect to the license plate light, left and right side light (not sure which lights they referring to) and display light. Question - is there any wire to tap for these lights signal? |
#21 | |
For the blue, that would go to the green wire on the bottom right of your picture. Those lights are switched on the positive side, rather than negative like the headlights. So, you will have to add a relay where the blue wire switches the ground side of the coil (and the positive side of the coil is connected to your ACC power wire). Then the normally open contacts will connect to the green wire on the headlight switch connector and to the green/white wire, which is the second to last wire on the opposite side of the bottom of the connector.
#22 | |
#23 | |
Attached are the illumination and headlight EWDs. Vios - Headlight.pdf Vios - Illumination.pdf
#24 | |
Tried to draw up something for the relay connection, is my understanding correct?
#25 |
Correct
#26 |
that's right I went there
Drives: '08 Blazin' Blue,'10 Dark Red Join Date: Oct 2008
sweet mod! never worry bout turnin on ur lights again
Mods : 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals. suggestions always welcome
#27 |
Finally managed to spare time trying out the installation. Some issue encountered, not sure if you could advice?
Without the relay connection for the parking lights, everything works well. It could auto on the headlight in the dark and off the headlight in the bright. But when I made the relay connection, it will auto on the headlight & parking lights in the dark but fails to off the headlight & parking in the bright. I could hear the relay switching sound but the headlight & parking lights remain on. Tried to change another relay, still having the same issue. Any idea what goes wrong?
#28 | |
Thinking of making some changes to the circuit by using the autolight sensor for the headlight portion. Below is the layout, not sure if this connection feasible? Any views?
#29 |
That should be fine.
#30 |
Do the headlights automatically come on when the stalk is in the off position? If so, can you still manually activate your headlights using the stalk?
#31 | |
For the sensor that i have installed, it comes with an on/off switch for me to disable the sensor as and when required. |
#32 |
Drives: camry 1998 Join Date: Nov 2016
Thank you very much for the How to ...
I know that is not the Camry 1998 forum. But have the YCL light sensor 301. I have installed HID lights in my 1998 Toyota Camry. I have tried many times to make the automatic light sensor work but I have never succeeded. My main problem is a brown wire. This "Brown" wire allegedly go to be connected to a "Mid Control Lock Down End" trigger anodic electricity. You have some solution, images or schematic for this situation. I'll be very grateful. Thank you very much for your help.
#33 |
I know that is not the Camry 1998 forum. But have the YCL light sensor 301. I have installed HID lights in my 1998 Toyota Camry. I have tried many times to make the automatic light sensor work but I have never succeeded. My main problem is a brown wire. This "Brown" wire allegedly go to be connected to a "Mid Control Lock Down End" trigger anodic electricity. You have some solution, images or schematic for this situation. I'll be very grateful. Thank you very much for your help. This is the Multi Switch Connector
#34 |
1998 toyota camry headlights combination switch connector plug
http://i438.photobucket.com/albums/q...102_190122.jpg |
| DIY Projector/HID (sedan) | Brian | DIY / Maintenance / Service | 145 | 02-05-2012 04:13 AM |
| Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison | CTScott | DIY / Maintenance / Service | 54 | 02-14-2011 08:58 AM |
| How To Smoked Sedan Headlight -DIY | zulhizainL902S | DIY / Maintenance / Service | 26 | 01-14-2011 02:12 AM |
| Glassylite Headlight Restoration Kit | TEHxFALLEN V1.2 | Photo-Video-Media Gallery | 1 | 07-03-2010 12:51 AM |
| HELP! I detailed my interior, and now having a headlight issue! | Astroman | DIY / Maintenance / Service | 4 | 06-08-2010 06:51 PM |
