Old 11-27-2016, 06:07 PM   #1
Pinchlite
Drives: 2007 yaris HB
springs
Thats my plan.I will not be putting on new wheels untill I lower.
I just was not sure 1.5 was enough as I have read many posts that say 1.5 is not even noticable?
Did you see the wheel and tirespecs I posted?
Pinchlite is offline   Reply With Quote
Old 11-27-2016, 06:08 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Well I'm on 195 55 15s and on teins so compare that size to urs and I'm 42 offset.
Sent from my HTC One A9 using Tapatalk
Old 11-27-2016, 06:13 PM   #3
Pinchlite
lowering
I already have this bought.
205/45R16 Comp 2
Wheels:16x7/4x100mm offset 40
Old 11-27-2016, 06:14 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
205/45R16 Comp 2
Just compare size... I say u should be find
Old 11-27-2016, 06:21 PM   #5
Pinchlite
lowering
Okay.Going to find some tein 1.5 springs within Canada and order them up.
I will get the springs installed ASAP so once summer arrives I just have to put on the wheels then get an alignment.
Thanks for you're and everyone elses help.
Old 11-27-2016, 06:23 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Have fun post pics after and teins are 1.9 drop but more like 2.o inch.
Old 11-27-2016, 06:34 PM   #7
Pinchlite
springs
1.9???? I thought it was supposed to be 1.5.
Why cant I get a proper answear.
I have spent days reading over many forums.Some say 1.5 not enough,others say 2'' too much.
I have a feeling I will be getting the improper spring height and wont be able to return after installation.
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 03:18 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
Should I lower the PSI during the Winter? paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-10-2009 10:12 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
