Old 11-27-2016, 06:13 PM   #1
Pinchlite
Drives: 2007 yaris HB
lowering
I already have this bought.
205/45R16 Comp 2
Wheels:16x7/4x100mm offset 40
Old 11-27-2016, 06:14 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
205/45R16 Comp 2
Just compare size... I say u should be find
Sent from my HTC One A9 using Tapatalk
Old 11-27-2016, 06:21 PM   #3
Pinchlite
lowering
Okay.Going to find some tein 1.5 springs within Canada and order them up.
I will get the springs installed ASAP so once summer arrives I just have to put on the wheels then get an alignment.
Thanks for you're and everyone elses help.
Old 11-27-2016, 06:23 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Have fun post pics after and teins are 1.9 drop but more like 2.o inch.
Old 11-27-2016, 06:34 PM   #5
Pinchlite
springs
1.9???? I thought it was supposed to be 1.5.
Why cant I get a proper answear.
I have spent days reading over many forums.Some say 1.5 not enough,others say 2'' too much.
I have a feeling I will be getting the improper spring height and wont be able to return after installation.
Old 11-27-2016, 06:36 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Tein springs are 1.9 but closer to 2 inch I run a set on my 07 Yaris 2 door
Old 11-27-2016, 06:59 PM   #7
Pinchlite
spring.
Okay.That sounds better.
Here is pic of 1.5 I believe.
Same tire and rim size as mine.
Tanabe DF210 with 16x7 +40offset on 205/45/16 tyres http://i.imgur.com/DSV3drZ.jpg
Can you post pic of your car with wheel and tire specs?
Also exact springs that you bought/have.
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 03:18 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
Should I lower the PSI during the Winter? paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-10-2009 10:12 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
