![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
springs
1.9???? I thought it was supposed to be 1.5.
Why cant I get a proper answear. I have spent days reading over many forums.Some say 1.5 not enough,others say 2'' too much. I have a feeling I will be getting the improper spring height and wont be able to return after installation. |
#2 | |
Sent from my HTC One A9 using Tapatalk |
spring.
Okay.That sounds better.
Here is pic of 1.5 I believe. Same tire and rim size as mine. Tanabe DF210 with 16x7 +40offset on 205/45/16 tyres http://i.imgur.com/DSV3drZ.jpg Can you post pic of your car with wheel and tire specs? Also exact springs that you bought/have. |
#4 | |
| Lower alternator bolt won't go back in, help! | Tmblackflag | DIY / Maintenance / Service | 3 | 01-21-2013 03:18 PM |
| Lower control arm replacement 2005 Echo ? | Infinitrium | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-27-2012 03:23 PM |
| Should I lower the PSI during the Winter? | paulyd0021 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 12-10-2009 10:12 PM |
| Should I lower the PSI during the Winter? | paulyd0021 | General Yaris / Vitz Discussion | 5 | 12-10-2009 06:49 PM |
