Fwiw 1.5" drop is more than noticeable. It made a huge difference in the appearance of my yaris.
Imo lower than that gives you the "wheels tucked in" look which I didn't want as it's not my thing and I wanted function over form. Also the car sits lower with a driver in it than what you'll see when you're standing beside it so take that into account. The springs will also settle after a few months of driving and will sit slightly lower
#2 | |
![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
Have any side pics. |
I'll look for pics but I just put my winters on.
My summer rims are 15x6.5 and +35 offset running 185/60 r15 I have 10mm spacers in the rear. The fit is very flush with no rubbing even when hitting the bump stops on rough Hamilton roads. Its the exact looks and function I wanted and couldn't be happier.
| Lower alternator bolt won't go back in, help! | Tmblackflag | DIY / Maintenance / Service | 3 | 01-21-2013 03:18 PM |
| Lower control arm replacement 2005 Echo ? | Infinitrium | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-27-2012 03:23 PM |
| Should I lower the PSI during the Winter? | paulyd0021 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 12-10-2009 10:12 PM |
| Should I lower the PSI during the Winter? | paulyd0021 | General Yaris / Vitz Discussion | 5 | 12-10-2009 06:49 PM |
