Old 11-27-2016, 07:17 PM   #1
Pinchlite
Drives: 2007 yaris HB
Originally Posted by tmontague View Post
Fwiw 1.5" drop is more than noticeable. It made a huge difference in the appearance of my yaris.
Imo lower than that gives you the "wheels tucked in" look which I didn't want as it's not my thing and I wanted function over form. Also the car sits lower with a driver in it than what you'll see when you're standing beside it so take that into account.
The springs will also settle after a few months of driving and will sit slightly lower
What wheel and tire size do you have?
Have any side pics.
Old 11-27-2016, 09:00 PM   #2
tmontague
tmontague's Avatar
Have any side pics.
I'll look for pics but I just put my winters on.
My summer rims are 15x6.5 and +35 offset running 185/60 r15
I have 10mm spacers in the rear. The fit is very flush with no rubbing even when hitting the bump stops on rough Hamilton roads.
Its the exact looks and function I wanted and couldn't be happier.
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 03:18 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
Should I lower the PSI during the Winter? paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-10-2009 10:12 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
