Old 11-28-2016, 11:44 PM   #1
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Also once u get ur springs I would recommend u spare them with under body rust proof stuff cos are winters are going to kill them fast do to the progressive spring setup....i used rock guard on mine before installing.
Sent from my HTC One A9 using Tapatalk
Old 11-29-2016, 06:13 AM   #2
Pinchlite
Drives: 2007 yaris HB
rockguard
Was already going to do the entire under floor while I had good access to underside.
But will do like you mentioned for sure.
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 03:18 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
Should I lower the PSI during the Winter? paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-10-2009 10:12 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
