Old 11-28-2016, 11:56 PM   #1
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Also cut down ur bump stops on ur struts, funny is I think I still have a set of sport line 1.5 drop springs around the house after I switched to tein springs, free if u want just need to find them lol
Sent from my HTC One A9 using Tapatalk
Old 11-29-2016, 06:09 AM   #2
Pinchlite
Drives: 2007 yaris HB
Wish I would have known earlier (I still have a set of sport line 1.5 drop springs around)
I ordered springs yest afternoon already
Some here on this forum said dont cut bumpstops???
Old 11-29-2016, 07:15 AM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Cutting bumps stops does make a difference in how it works. You gone go lower so you want suspension travel not ride on the bump stops lol
Old 11-29-2016, 07:19 AM   #4
Pinchlite
cut
I seen a post where they were cut down.
How much do I leave attached?
I will be doing the springswap my self aswell as adding swaybar.
I did replace struts on a civic almost 20 years ago so i know I can do it.
Old 11-29-2016, 09:48 AM   #5
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Simple logic ur car will sit 1.5 inch lower so why would u use stock hight bump stops cut 1 inch off at least or every other bump u will hit them and restrict ur suspension travel...also good luck with swaybar links they are fun to remove, use heat if possible also remove wipers and all in that are 10 min job to get to the top shock mounts.
Old 11-29-2016, 12:00 PM   #6
Pinchlite
spring
I have a small oxy-acet torch and have used it for similier nuts.
I will cut one inch off.I actually already had the cowling removed previously,piece of cake.
Thanks for the pointers.
Just trying to locate a reasonably priced sway within Canada.Stillwaiting back for a few replys.
Old 11-29-2016, 12:22 PM   #7
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
I will see if I can get u a TRD swaybar at cost, I'm no longer with Toyota but my buddy is still there and is a parts guy.
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 03:18 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
Should I lower the PSI during the Winter? paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-10-2009 10:12 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
