![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
cut
I seen a post where they were cut down.
How much do I leave attached? I will be doing the springswap my self aswell as adding swaybar. I did replace struts on a civic almost 20 years ago so i know I can do it. |
#2 | |
Sent from my HTC One A9 using Tapatalk |
spring
I have a small oxy-acet torch and have used it for similier nuts.
I will cut one inch off.I actually already had the cowling removed previously,piece of cake. Thanks for the pointers. Just trying to locate a reasonably priced sway within Canada.Stillwaiting back for a few replys. |
#4 | |
swaybar
Not sure if I can even afford that @ cost?
at least not at the moment. Between full stereo components upgrades,rims,rubber and springs the budget is almost tapped out. I may need to cut back on my other hobby
#6 | |
swaybar
180.00 CAD!
That may be workable..especially since its a quality unit. I appreciate all the BTW. Much appreciated. I would even consider used items if need be. |
| Lower alternator bolt won't go back in, help! | Tmblackflag | DIY / Maintenance / Service | 3 | 01-21-2013 03:18 PM |
| Lower control arm replacement 2005 Echo ? | Infinitrium | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-27-2012 03:23 PM |
| Should I lower the PSI during the Winter? | paulyd0021 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 12-10-2009 10:12 PM |
| Should I lower the PSI during the Winter? | paulyd0021 | General Yaris / Vitz Discussion | 5 | 12-10-2009 06:49 PM |
