Old 12-12-2016, 02:00 PM   #1
David C
Drives: White '07 3dr LB
Got around to an elegant solution. With my 1000w power inverter running off a group 27 deep cycle battery, with a parallel switch on a timer relay activated by my remote starter for the inverter, I bought a 750w Vornado personal space heater which I position on the floor in front of the front passenger seat, aiming to the center console, and plugged into the inverter. So far even at -7° C, running for only 5 minutes, the car is already cozy. Draw about 10% off my secondary battery per 5 minutes of use, which is being recharged later on the road when the engine is warmed up. It won't defrost the car, but it's terribly effective at warming up the cabin space in a very short time.
David C is offline   Reply With Quote
Block heater R2D2 DIY / Maintenance / Service 80 04-24-2025 04:08 AM
Block Heater Hole Location? bronsin DIY / Maintenance / Service 2 11-05-2011 06:54 PM
is it hard to add a 12-volt auxilliary power outlet? RMcG DIY / Maintenance / Service 1 10-10-2011 01:19 AM
Rostra seat heater and lumbar support sesmith In Car Entertainment + Electronics (audio / video / alarm) 1 01-03-2009 08:51 AM
