Old 11-05-2011, 12:44 PM   #1
bronsin
bronsin's Avatar
Block Heater Hole Location?
I cannot for the life of me find it!
I have removed the battery and have looked on the drivers side of the cylinder head. Which is where I thought it was.
Is it on the backside of the cylinder head? The part that parallels (nearest) the firewall?
Enquiring minds want to know!
Old 11-05-2011, 02:18 PM   #2
bronsin
bronsin's Avatar
I found the hole.
But cant seem to get the clip to engage.
Its at the 4 o clock position, facing the hole I guess.
Old 11-05-2011, 06:54 PM   #3
Idahotom
Drives: 2008 5 sp. LB
I found the hole.
Keep at it! I found the info I needed last year by searching past posts here. At one point I about gave up, but in the end it was no big deal, one of those things you could do in a fraction of the time the second time around!
Idahotom is offline   Reply With Quote
Block heater R2D2 DIY / Maintenance / Service 80 04-24-2025 04:08 AM
engine block heater linny DIY / Maintenance / Service 6 01-19-2012 11:22 AM
Yikes, thats an expensive block heater HDS DIY / Maintenance / Service 2 12-17-2009 07:30 AM
Where to find block heater cable that was factory installed? D6U4 General Yaris / Vitz Discussion 5 12-16-2008 07:04 AM
