Old 04-19-2007, 11:31 AM   #1
webmaster
BX
Send a message via AIM to webmaster Send a message via MSN to webmaster Send a message via Yahoo to webmaster
MY pAsssenger side door wont open
my door does not open on the front passenger side
it seems the door lock is jammed or something
i cant get the door panels open because the door is closed
i took it to the dealer but because i had body work done on the same door last year they said wont take a look at the car without charging me to fix it
anyone with ne ideas??
thanks in advance
webmaster is offline   Reply With Quote
Old 04-19-2007, 11:40 AM   #2
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Send a message via AIM to vodkalush
Did the dealer do the body work? If not, I'd take it to another dealer and not mention the body work...
also (i'm guessing you tried, but i'll ask). have to tried to do the following:
- open from inside
- unlock (manually - on door) and open from inside
- unlock (manually - on door) and open from outside
Docotrs say all the drikning has mesesd up my seplilng and radieng
will work for parts
vodkalush is offline   Reply With Quote
Old 04-19-2007, 11:50 AM   #3
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
I can easily see how this would happen. Has the the door panel ever been removed? Upon reinstallation, if the lock switch cable wasn't properly seated into it's groove and poped loose, you could lose function of the switch, which I think you have. The panel needs to be taken off to correct the problem. How to open the door first, not sure...
PetersRedYaris is offline   Reply With Quote
Old 04-19-2007, 12:24 PM   #4
ChinoCharles
Drives: LB
Take the door panel off. It takes all of 10 minutes and the locking mechanism is really simple. I'd bet that is where your problem is.
Old 04-19-2007, 12:29 PM   #5
PetersRedYaris
The problem is, he can't open the door.
Old 04-19-2007, 12:31 PM   #6
vodkalush
I drive a yarrrris
vodkalush's Avatar
the issue is taking the panel off... i'm not sure if you can do it with the door closed, i'll check when I go for lunch and post when I get back if no already has.
will work for parts
Old 04-19-2007, 02:54 PM   #7
i had a problem with that too. my dealer fixed it w/o charge.
Old 04-19-2007, 02:55 PM   #8
but for me, it didn't deal with the locks, but the cable/link on the door latch (i think).
Old 04-19-2007, 08:05 PM   #9
punch
punch's Avatar
Drives: 2007 Yaris Sedan "D" package
you need a slim jim my freind call a tow truck they might be able to open the door.
punch is offline   Reply With Quote
Old 04-19-2007, 10:35 PM   #10
vodkalush
I drive a yarrrris
vodkalush's Avatar
yah, slow response... but there is no way that i can see to remove the door panel inside without the door open.
Above post says it all
will work for parts
Old 04-24-2007, 08:11 PM   #11
webmaster
BX
Hello
I got it fixed !!!
I did it myself it took awhile to get the panel open.
and it wasnt the cable or anything
the locking mechanism was jammed so i just gave it a push and it stated working fine
very odd it was working a good 6 months since my body work on it
nehows thanks evryone for your input
just in case someone else has the same issue
to get the door panel open with the door close
1/open window
2/grab the panel edge where the window opens and
3/ pull up and out
4/ use alot of force!!
the entire panel wont open but enough to get your hand into the locking mechanism
Old 04-24-2007, 08:43 PM   #12
sambo42xa
Drives: 07 YARIS Automatic/LiftBac/Red
"but the sign said "FINE FOR HUNTING"
curley
"The Three Stooges"
sambo42xa
sambo42xa is offline   Reply With Quote
Are the optional airbags worth it ? avenno2g7 General Yaris / Vitz Discussion 46 12-07-2008 03:40 AM
so close, cant decide roxy84 General Yaris / Vitz Discussion 31 04-13-2007 09:22 AM
Please open the DOOR CAREFULLY! Rahxephon Off-topic / Other Cars / Everything else Discussions 34 12-21-2006 09:25 AM
Cannot open the driver door when unlocking from the outside. Rahxephon DIY / Maintenance / Service 10 12-02-2006 10:18 AM
