Old 01-21-2017, 08:10 PM   #1
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Basically any source of air from ahead of the radiator/condenser. About 1/4 of the surface area of the heat exchangers actually flow air...so all that extra air needs to go somewhere. This is where most OEMs source outside higher pressure air to aid in performance
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 01-21-2017, 11:59 PM   #2
So if I can some how route the ducting to the side, bottom, or top of the radiator, it should be sufficient? I saw an article online about how on an NA gen Miata, there was a good duct placement at the cowl. I don't think the Yaris has any space near the cowl tho.
Finding Remote/Iginition Wire 2016 Hybrid drdyzio Third Gen Yaris General Discussion 1 11-14-2016 05:34 AM
Help finding part number joell DIY / Maintenance / Service 19 01-06-2015 02:41 PM
Need help finding the Japanese part number for the TRD Sway Bar (PTR11-52071) chalked Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 01-26-2013 02:29 PM
need a hand finding these spacers mr_miles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 12-11-2011 08:18 PM
I need help finding 17's for my ride Stoln Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-18-2009 07:21 AM
