Old 01-22-2017, 11:08 AM   #1
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
Put in new plugs and clean or change the MAF sensor. Also change the air filter, unless it's already been changed recently. Those are the basic things you need to do. Then check the mileage again.
Sent from my LG-D801 using Tapatalk
tarkus is offline   Reply With Quote
Old 01-22-2017, 11:11 AM   #2
Motzking1
Motzking1's Avatar
Drives: 47 2013 yaris l hatchbacks
Why would you replace spark plugs. There is no engine misfire. That is not the problem here. And engine misfire would illuminate the malfunction indicator lamp or a check engine light. Replacing the spark plugs at this point for anything other than maintenance will not help the problem.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Motzking1 is offline   Reply With Quote
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Winter Gas Causing Drop in MPG? MadMax Fuel Economy Forum 66 03-21-2010 04:46 PM
Gas mileage logging online? colb Fuel Economy Forum 8 03-13-2009 03:41 PM
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 04:31 PM
Tired of poor gas mileage & buying premium gas. Boosted Peon New YARIS Purchase Forum 29 08-25-2006 08:59 PM
