Old 01-22-2017, 09:20 PM   #1
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
Nothing to do with misfiring. Heavily used spark plugs degrade engine performance.
Sent from my LG-D801 using Tapatalk
tarkus is offline   Reply With Quote
Old 01-22-2017, 09:26 PM   #2
Motzking1
Motzking1's Avatar
Drives: 47 2013 yaris l hatchbacks
Heavily used? They haven't even reach the factory maintenance interval of a hundred twenty thousand miles? And I would like for you to explain the mechanism of action of how a used spark plug in any fashion that is working perfectly normal is going to have any adverse reaction at all on the engine. There is a federally mandated very sophisticated monitoring system to make sure if there's any issue whatsoever with the spark plugs that would cause any incomplete burn or anything all that would cause an incomplete burn in the cylinder that would eliminate a malfunction indicator lamp mil. The systems are extremely sophisticated and extremely effective. Hundreds of millions of dollars of research shared among all manufacturers has gone into designing these systems to be extremely effective. So you want me to disregard all of that and believe that you know better when to replace the spark plug?
Sent from my SAMSUNG-SM-N900A using Tapatalk
Motzking1 is offline   Reply With Quote
Old 01-23-2017, 11:51 PM   #3
alias06
Drives: 2008 Red Toyota Yaris
If I am reading your post correctly you are referring to the O2 sensors giving a MIL when something goes wrong. As sophisticated as they are, they do not always tell the whole truth to the problem. There are many steps involved in the system before it will actually trigger the light. One example of this would be for an issue to happen more than once within a certain drive cycle such as if a single misfire was to happen within 500 miles of driving the light will not come on but it doesn't tell you that you had a misfire. But let's say that you have a misfire every mile you drive, that'll more likely trip the light. Just because you don't get a MIL doesn't necessarily mean everything is operating at full potential. Also OP stated that the mileage is at 105K miles, I wouldn't say that is too far off from the 120k you stated. Some mechanical items fail earlier and some lasts longer, its all subjective to abuse and maintenance.
alias06 is offline   Reply With Quote
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Winter Gas Causing Drop in MPG? MadMax Fuel Economy Forum 66 03-21-2010 04:46 PM
Gas mileage logging online? colb Fuel Economy Forum 8 03-13-2009 03:41 PM
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 04:31 PM
Tired of poor gas mileage & buying premium gas. Boosted Peon New YARIS Purchase Forum 29 08-25-2006 08:59 PM
