Old 02-03-2017, 09:19 AM   #1
tmontague
tmontague's Avatar
any chance you can give a description of how you added the wire to the fuse box from the fuse to the connector?
Does the fuse box just lift up to give you access? I like the clean look of it
Old 02-03-2017, 10:14 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Take a look at the pictures on the front page. It's hard to get a good shot though, because it's all black plastic. Basically, I just populated one of the empty fuse slots and plugged the other end into the empty position on the connector. You have to separate the two bottom parts. There's 7 or 8 tabs that hold them together, and it's more easily accomplished with the fuse box unbolted from the frame. If you get one from a junk yard and break it down, it will make much more sense. I think just about any Toyota fuse box would be OK, but a Yaris or Echo would be best.
My 2zrfe swap brushforhire Performance Modifications 131 06-08-2016 09:43 PM
1nzfe throttle body swap and fitment questions EchoBob02 Performance Modifications 14 05-01-2014 08:02 AM
FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) AdeJong 03 Items for Sale by private party 4 04-05-2010 11:25 PM
Gauge Cluster Swap, other interior swap questions. Adrenalingirl_K In Car Entertainment + Electronics (audio / video / alarm) 4 04-09-2009 03:32 AM
