#1 | |
![]() ![]() ![]() Drives: White '07 3dr LB Join Date: Jun 2016
Changed cluster have some questions?
How long has this fix been around ?? I have a '07 HB auto with ABS that the light is on due to a faulty sensor or whatever else problem that cause the ABS to disengage and it's annoying to have it on. So far it's the first time in a year that I've seen a way to reset that light without clearing and fixing the fault. The two steps are to jump the pins and press the brake 8 times in 5 seconds then you can remove the jumper and its done ? Envoyé de mon iPhone en utilisant Tapatalk |
#2 | |
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
1. Jump terminals 4 and 13 of the OBD2 port 2. Turn ignition to ON (not running) 3. Press brake pedal 8 or more times within 5 seconds 4. Remove jumper wire or paper clip 5. Turn off ignition This will clear the light but if the fault is still present in the ABS system the light will come back on eventually. There's also a procedure to read the ABS fault codes which the same as the clearing one except without the brake pressing part. After you jump the terminals and turn the ignition to ON the ABS light will blink in a pattern to indicate the code(s). |
| Instrument cluster swapout help | JudgeM | DIY / Maintenance / Service | 39 | 08-30-2025 09:19 PM |
| 3rd Gen Gauge Cluster Swap :D | KenTK808 | Third Gen Yaris General Discussion | 22 | 10-21-2017 07:58 AM |
| Willing to trade 2010 MPH liftback cluster w/tach w/ABS for cluster w/tach wo/ABS | Jabro | Willing to Buy by private party | 4 | 12-21-2012 06:34 PM |
| FS: Gauge Cluster from '09 LB- $150 | MGargano | Items for Sale by private party | 14 | 10-05-2009 12:59 PM |
| Gauge Cluster Swap, other interior swap questions. | Adrenalingirl_K | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 04-09-2009 03:32 AM |
